configure iparp max_proxy_entries
configure iparp max_proxy_entries max_proxy_entries
Description
Configures the maximum allowed IP ARP proxy entries.
Syntax Description
max_proxy_entries Specifies maximum number of IP ARP proxy entries.
Default
256.
Usage Guidelines
Range: 0–4,096.
The following example sets the maximum IP ARP proxy entries to 500 entries:
configure iparp max_proxy_entries 500
This command was first available in ExtremeXOS 11.0.
Per virtual router capability removed in ExtremeXOS 30.1.
Platform Availability
